Next best thing to a Panasonic TH37500?
Discussion in 'Plasma TVs' started by crommy, Sep 9, 2005.
  1. crommy
    crommy
    I've been waiting for the Panasonic TH37PV500 for a while now but no one seems to have any in stock. So I've decided to go for the next best thing.
    Has anyone got any recommendations?
    Thanks for your help.
  2. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,024
    2
    4
    137
    Garstang, Lancs
    +1,582
    Some like the new Samsung but that is 42", other than that, you choice is limited at 37"
  3. crommy
    crommy
    Going above 37" isn't ideal as I've not got that much space where I'm going to put it. I'd definitely want one HDTV though.
  4. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,024
    2
    4
    137
    Garstang, Lancs
    +1,582
    Have you compared the dimensions, I don't think the samsung 42" is much bigger, I may be wrong.
  5. tscotsman
    tscotsman
    Dec 29, 2004
    848
    +15
    i would just be patient, by all accounts the panasonic is the one to have if you can afford it. Im waiting for my 42" should have it next week (hopefully!!) so says John Lewis
  6. Not A Clue
    Not A Clue
    Ideally you should wait and buy the one you have your heart set on - removes any doubts later in life !
    If you cannot wait and are not overly interested in High Definition then I would go for the Panasonic 37PE50 - its the Standard Definition model of the one you have....this will also be a heck of a lot cheaper.
  7. D J C 197
    D J C 197
    Sep 6, 2005
    1,342
    48
    +47
    Oh no,
    I've just looked on Currys website and they are out of stock too. I hope they get some shortly because I'm due a replacement one as my 10-day old set is faulty.
    I want my new one sooner rather than later so i can have it run in for my 360. :mad:
