Nexnix screen is this one ok?
Discussion in 'Projectors, Screens & Video Processors' started by sanjuro, May 26, 2004.
  1. sanjuro
    sanjuro
    Jun 30, 2003
    168
    2
    +5
  2. Godfather
    Godfather
    Feb 12, 2001
    2,345
    63
    Edinburgh
    +225
    I've got the 180cm wide (81" diagonal) one from Nexnix. It's excellent, hangs completely flat with no ripples etc.
  3. iansimpson888
    iansimpson888
    Aug 17, 2003
    381
    46
    Standish
    +207
    I've got the 180cm Nexnix Screen also
    Use it with the HT1000
    Very pleased with it
    (Although I've never had naything to compare it to other than my initial temp solutions - a bare wall, then a white shower curtain mounted on a chuckle brothers type wooden frame)
  4. sanjuro
    sanjuro
    Jun 30, 2003
    168
    2
    +5
    Thanks for the replys guys i think i will order on tuesday
    sanjuro
