Nexnix bundle question...
Discussion in 'Plasma TVs Forum' started by bigval, Jan 24, 2005.
  1. bigval
    bigval
    Dec 30, 2004
    1,018
    48
    +27
    http://shop.nexnix.co.uk/NexNix_Online_Shop_Panasonic_232.html
    will the:- 1x Hitachi HTDK185 5.1 Surround Sound & DVD system with Freeview Digital TV Tuner give me all I need to get sound from the system?
    Or do I still need to buy an amp?
    If sky+ , dvd and console can go thru it then it could be the one for me....
    Really finding this hard. Got to get it right tho
  2. absthechatter
    absthechatter
    Nov 27, 2004
    159
    It will give you the sound you want (not too sure of quality though, it's quite low range & Argos are flogging them for £99.99 at the moment). Also not too sure what connections there are on the back and whether you could put all your equipment through it - I am sure NexNix will help though, they are very good and just a few miles down the road from me.
    Abs
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    you would still need a switch to handle multiple video connections......
