The 5 channel RX-V4A features 80W of power per channel while the beefier and more expensive of the two models, the RX-V6A is a 7 channel AV receiver with 100W per channel.
The new models both incorporate a newly designed High Slew Rate Amplifier circuit which means they can adapt more quickly to rapid changes in input level and are suitable for high resolution audio signals.
No no no... Sound United has told us this is way too expensive and nobody wants it!Well done on the multiple hdmi2.1 ports!
I wonder if Yamaha have the same chipset (except sourced more) or did the go down the LG 2019 route and make a custom chipset so they could cover more ports. Or did they reverse Sound Uniteds implementation and go 2 ports in, 1 port out, a bit more clarification requiredNo no no... Sound United has told us this is way too expensive and nobody wants it!
Good to see Yamaha doing it properly, looks like I have found my new amp to replace my aging V677.
'Dolby Atmos Height Virtualization' sounds like marketing guff, but generally Yamaha's virtual setups tend to be pretty good, so looking forward to seeing if that makes any real difference or not.
Hopefully the prices see a bit of a dip after launch, £650 is a little bit steep, but I would imagine it will be closer to £500 by Black Friday.
I see that even hardware now is 'beta' on release.
Custom chipset with an entire re-design of the internals was required according to one dealer. Apparently HDMI 2.1 boards are tricky beast s(not the doubling in the HDMI power supply) - ventilation is also the key, hence the side vents on the new amps + increased venting in general.
These are entry level Yamaha's, what the Aventage range has to offer will be interesting.
No plans for a 9.2 / 11.2 variant?
The smaller LCD footprint is unfortunate, can show a lot of info, but from a distance will be difficult to see (mind you, phone app will show most info)
Another fact that some may find interesting. Yamaha appear to have forsaken Burr Brown and look to have ditched it in favout of Texas Instruments DACs onboard their new V series receivers? The V6 includes the 384 kHz / 32-bit BB PCM5102A while the V4 uses the 384 kHz / 32-bit BB PCM5101A DAC.
