Sony KD-49XG9005.What TV do you have?
Is that with the V6 and the new remote or the new 360 STB?In general I'm pretty happy with the update to 360. It feels much more responsive, layout is cleaner, the remote is less cluttered and the voice control works well. The user option is also useful to create your own guide. Setup was simple and the single v6/tv off function is nice. The removal of when a show was first aired or whether it's a new show is annoying. Looking forward to adding to the 2 V6's with mini box's upstairs when available.
It looks like the fix is half implemented at the moment, there's a drop down for episodes to record but there is only 1 option - to record all episodes.I did the upgrade last week 2 V6 boxes with new remotes and no issues but took a bit longer than I expected for the last bit to update channel listings.
So far I like it quick neat interface and the only thing for me that needs sorted is the series link options which is supposed to be coming soon.
"Maxit" refers to the TV package, "Oomph" is the overall package including phone, broadband and mobile SIM.Still confused. Our package says TV, full house. In the upgrade section it offers something called Maxit for a bit extra per month. I don't see any mention of anything called..oomph.
If you only have one TV and one V6 box, is this 360 box pointless? Is it mainly about multi room? We've never recorded anything, and just use the V6 to watch TV. Then use the TV apps for stuff on Netflix, prime etc.
From what I've read, I can't see any advantage of the new box. Can't see any disadvantage either
Ah. Ok. Thanks for that. Not with them for mobile, so probably not getting it then. Yet anyway!"Maxit" refers to the TV package, "Oomph" is the overall package including phone, broadband and mobile SIM.
The 360 isn't really about multi room, it is a new software for the V6 box. It has a far better UI (IMHO) than the old system and comes with voice control. There's no drastic advantage over the old system really.
But there is 1 drastic disadvantage at the moment,the inability to select just new shows to record in series link.For that alone I wouldn't want to 'upgrade'"Maxit" refers to the TV package, "Oomph" is the overall package including phone, broadband and mobile SIM.
Yeah, that's my main bugbear with it at the momentBut there is 1 drastic disadvantage at the moment,the inability to select just new shows to record in series link.For that alone I wouldn't want to 'upgrade'
Yes, you need to set your Harmony to control a "Ziggo Mediabox Next" in order to operate the V360.Does anyone know if the remote also works with IR and uses the same signals as previous one? Main concern is we use a logitech harmony system at home so would be annoying if that can no longer independently control the box...
