NEWS: Virgin Media and Openreach: Our networks can handle surge
BlueOrange25
I'm a Virgin customer. Pretty impressive how they've been managing so far.
Under normal circumstances, Virgin's internet connection drops a 1-3 times a week - for around an hour at a time - in my area (London commuter belt).
Speeds have taken a hit and the connection still drops - but not significantly more than usual. (I get the odd 'mini'-drop here and there but it's done in 10 minutes.)
Credit where it's due. Unprecedented demand and I underestimated Virgin.
lomax512
I don't mind if they throttle back speeds so households operate at say 100Mbps instead of 200Mbps as long as businesses can survive, anything to help.
xxGBHxx
Plusnet is creaking a little speed wise but nothing to worry about.
I'm guessing it's one of the benefits of having a telecoms industry built on a proper "unlimited" basis. It means that it's built with plenty of spare capacity.
G
ggwoodland
Virgin is working pretty well for me in north London as well. I noticed that the streamers have reduced their bit rates and video/audio quality has taken a small hit but I am fine with this in the circumstances - george
BillRawles
Touch wood but no issues with VM (we've got 100mbps) out in the Essex sticks. The work VPN has been connected for over a week without a drop. Also no issues with streaming services in the evening. Long may it continue.
Suave
Hi All,
Apologies for possibly detracting from the thread but I have Virgin 100mb & for the last two years regularly get multiple freezing on my internet - this is whether it is hard wired or WiFi - it happens many multiple times a day & it completely random - can happen 5 times day or 30 - the freezes last from anywhere to a couple of minutes or much longer.
Does anyone else with Virgin experience anything similar - Virgin simply do not want to know despite pleading with them & refuse to send an engineer out.
Many Thanks!
Tempest
Will people get refunds?
I don't but if you pay extra for a higher quality, then then cut the quality, should they then at least not credit you back the difference?
They are the ones that decided to charge customers more.
anlygi
Hi All,
Many Thanks!
I had the same issues after 'upgrading' my Superhub 2AC for a Superhub 3. Bought an Asus router about 2 years ago now and put the Virgin Superhub 3 into modem mode. I only ever reboot now for a firmware update on my Asus router which has been twice in that time from memory. No drop-outs, rebooting the hub, much better Wi-Fi coverage and better controls. I cannot guarantee a new router will fix your problems, but highly likely. The Virgin Superhub 3 is a pile of 💩.
rallychief
well we have a 100mb service with Virgin, and all through the latter part of last week had less than 2mb pretty much all day and evening, oddly it has improved back up tp 15-20 mb this weekend
anlygi
That's beyond shocking. I thankfully must live in an area of low contention as there is not even the slightest drop at any time of the day. All of my neighbours within Wi-Fi range at least are on Sky, BT and TalkTalk. Have you ruled out a router problem?
rallychief
So now Monday morning 11.20 just done 2 speed checks one with speedcheck and one with Fing, as a cross check , both show download in region of 2.5 mb upload in region of 6 mb have reset router won't even bother to try and ring virgin, seen the chaos in India, where of course the call centre is.
Cheers Chris
IronGiant
Getting 80.76 down and 21.02 up from Virgin here in Oxford, so something isn't right where you are.
rallychief
We live in a cul de sac right at the end of an estate furthest away from the nearest virgin distribution box don't know if that makes a difference just checked again 13.10 now download 16.97 upload 9.07
Violator
80D/20U with Sky Fibre. No slowdown noted here last couple of weeks.
Bugbait
...The Virgin Superhub 3 is a pile of 💩.
Pretty much this. I've always used my own router since the supplied ones are cheap garbage. My first Virgin router several years ago couldn't manage a stable connection to WiFi devices 30cm away with no obstructions. The replacement would drop under decent load.
Modem only with an Orbi? Only drops are when the service goes down (thankfully not too often). It slowed a bit a few weeks ago to 80 down but still 15 up. Has been a solid 375 down and 15 up since then though. Can't say the same for client site where their virtual desktop environment is throttling.
rallychief
So are you saying the problem is the super hub 3 ? why am i getting such a huge variance from 2.5 meg to nearly 50 over a 4 hr period, never checked it over a period like today before, i was having issues last week and checked it, found it was down to 2 mb like this morning
Bugbait
If it's speed variance it's more likely a contention issue (too many users). If it's stability and local WiFi then could be a router issue.
Aj33
Virgin 210-220 up and 20-25 up.
rallychief
So with the wide variance at different times 1.18 down 1.05 up now 17.49 !!!! its the extra demand so Virgin saying they have the extra capacity is rubbish
Aj33
I would suspect your router.
rallychief
Ok so what do i do, assuming the router is at issue, their is no way i will be able to get it sorted with Virgin just now, assume i will need to replace it, so what should i get, ( yet another parcel to disinfect )
Podcast: CES 2021 Special - Sony, LG, Panasonic, Samsung, TCL and Hisense TV news and more...
Latest News
Sky seals Studiocanal movie deal
  • By Andy Bassett
  • Published
iFi Audio launches iDSD Diablo DAC/Headphone amp
  • By Andy Bassett
  • Published
Samsung launches Galaxy Buds Pro
  • By Andy Bassett
  • Published
Samsung launches Galaxy S21, S21+ and S21 Ultra smart phones
  • By Andy Bassett
  • Published
Mola Mola debuts Kula integrated amplifier
  • By Andy Bassett
  • Published
