DB9S
Hi. Couple of things.
Set the PC resolution to 3840x2160 NOT 4096x2160. You will get more menu options that way.
Also set your HDMI ports for 'Full' for 'Dynamic Range' and to 'Enhanced Format'.
These will set the range to 0-255 for the PC output and Enhanced to enable full 18Gbps for full fat HDMI.
As for PC will likely be outputting 60hz, then when set to Standard Format (default settings) then the projector will only accept 8bit colour @60hz.
i.e. Not HDR.
i.e. Not HDR.
