For those who have access to UniDays, the 15% discount works on the pre-order, so I've managed to get one ordered for £135.15![]()
Richer Sounds has it listed as: 62 x 60 x 168Has anyone checked the dimensions of this device? The dimensions given - 240 x 160 x 126 - suggest a truly enormous hand is holding it!
That sounds a bit more like it. Looks like the dimensions from Andy B might be for the box it came in.Richer Sounds has it listed as: 62 x 60 x 168
Based on recent Sonos releases and stock shortages then if you want one this side of summer you'd be best off pre-ordering and returning if you don't like the sound.Very interested in this but I’m going to wait for reviews after release. Separate tweeter, mid and trueplay means this looks promising for a balanced sound and something that can easily be moved from room to room or taken outdoors.
I don’t have Sonos at the moment so did not know that. Thanks for the heads up and have ordered two!Based on recent Sonos releases and stock shortages then if you want one this side of summer you'd be best off pre-ordering and returning if you don't like the sound.
According to Sonos no unfortunatelyCan you use this as surrounds? WoulD love a small surround speaker
Damn! That would have swayed it for me. It’s good an opportunity to waste IMO.According to Sonos no unfortunately
I guess they have the ability with a software update but they probably don’t want to cannibalise sales of the ONE.Damn! That would have swayed it for me. It’s good an opportunity to waste IMO.
