NEWS: Philips TV and Bowers & Wilkins sign exclusive partnership deal
Discussion in 'Philips TVs Forum' started by Phil Hinton, Jun 19, 2018.
    1. Mark Hodgkinson
      Mark Hodgkinson
      Reviewer & News Writer
      Aug 8, 2005
      14,053
      3
      4
      +4,450
    2. encaser
      encaser
      Mar 15, 2001
      2,808
      Suffolk/Essex
      +730
      Ironic that both are more namesakes now and that B&W are not big on bass (or at least 'exaggerating' it) and it's at the lower registers that it's particularly needed in TVs of late.
      It'll be interesting to see if this new design ends up somewhat in line with B&O for a speaker size that isn't trying to defy the laws of physics to produce what's needed.
    3. Goldorak
      Goldorak
      Jul 30, 2011
      5,079
      Kent uk
      +3,895
      Good development and also started with LG and meridian. More integration needed but glad focus is also on sound. About time
    4. RichardG
      RichardG
      Apr 28, 2003
      208
      28
      Cardiff, UK
      +27
      I agree - B&W and Philips are suggesting they're offering something new and that the problem hasn't already been solved.
      The B&O Eclipse is so far ahead in terms of sound quality compared to other TVs that it's not even a fair comparison. It's more like a TV attached to an audio system than the other way around. That comes at a price obviously, and the best the B&W and Philips can hope for is to get somewhere near B&O's performance at an affordable price for the rest of us!
    5. drdoom2k
      drdoom2k
      Jan 4, 2018
      238
      46
      London
      +163
      How about bringing some TVs to the UK that we can actually deploy the enhanced sound with? :devil::rotfl:
    6. encaser
      encaser
      Mar 15, 2001
      2,808
      Suffolk/Essex
      +730
      Three companies not striving for value markets.
    7. AdtAdt57
      AdtAdt57
      Jul 10, 2016
      16
      4
      North Bucks Village, UK
      +3
      Well, I’ve had many Philips TVs going back to the PalPlus CRTs, which obviously had room for decent sounding speakers as the TV could act as big speaker enclosure. Even bigger as the TV screen size grow to 32”+, my last was the 32PW9617/05. These all sounded very good for everyday use, however, I’ve always had a separate AV Amp and Speakers, which a TV should in my opinion NOT try to replace. When I switched to Philips first high-end LCD TVs it had the then new NXT flat speakers, the Cineos 32PF9830/10, which also sounded very good. This was followed by the more conventional 32PF9986/12, then the 42PFL9803H/10 and finally the 40PFL9704H/12, yes a smaller but better HD picture. These all had very good sound indeed... Last year I was blown away with the new OLED and have a 55POS9002/05, which is by far the best picture I’ve every seen...
      So why I have said all the above?, well the sound from the ‘razer thin’ OLED TV is really rather poor compared to all previous Philips TVs - it’s weak across the full spectrum, especially bass and I don’t mean ultra low bass that dominates much modern music :-(
      My relatively small (WxHxD - 29x19x9 cm) Pure DAB kitchen stereo radio actually sounds quite a bit better, which is a crazy state of affairs. Of course, as I have a separate AV Amp and 6 large Speakers, the fronts being large enough not to need a Sub, I really don’t mind. When watching news and some mainly voice only programming the TV sound is OK and when I need to I can switch to the Amp. Philips only provide one optical audio out which can’t handle the highest multi-channel sound if they had provided an audi only HDMI output like high-end Blu-ray players.
      Philips are obviously aware of this sound issue, as they now have a nice low profile sound bar for £850 - the B8/12 Fidelio Nano, Amazon now offer this as a bundle for this TV. This is so low in profile it doesn’t block the picture when the TV is on its low stand. I thought about it, but it’s rather expensive to make up for poor inbuilt sound and would add a bit of clutter to my setup. The TV is <5 mm thick for around a third of its height from the top down, with the rest then only 47.5mm so there’s not much room for speakers, however, more could have been done. I hope that the B&W partnership will help both to keep the TV profiles reasonably small but with much better sound built in and then also provide add on units for those that don’t have separate high-end home cinema AV Amp and speakers...
    8. Goldorak
      Goldorak
      Jul 30, 2011
      5,079
      Kent uk
      +3,895
    9. encaser
      encaser
      Mar 15, 2001
      2,808
      Suffolk/Essex
      +730
    10. Goldorak
      Goldorak
      Jul 30, 2011
      5,079
      Kent uk
      +3,895
      You are indeed right. I just wonder if the supplier is still b&w as I will not be surprised the discussion started years ago...time doesn’t flow the same for Philips :)
    11. encaser
      encaser
      Mar 15, 2001
      2,808
      Suffolk/Essex
      +730
      No, as I said it's in house for the art one and the first has a tiny unlabelled speaker which is not B&W style.
    12. Mane UK
      Mane UK
      Jun 17, 2018
      116
      Hertfordshire
      +14
      With tpv having acquired the Philips audio license from Gibson (or was it woox?) I was hoping for something like the magnetically detachable speakers for the rear channels - like the B5 soundbar or E5 speakers. Maybe an OLED panel sold cheaply without any speakers, with different optional magnetic speaker packs coming in slim design or 5.1 or whatever.
    13. 94jdh
      94jdh
      Feb 28, 2007
      718
      46
      +172
      I do like the magnetically detachable speakers, I feel they offer a better sound option and there is a definite noticeable difference between 8601 and 7601 models in everyday use - its hard to find the balance for customers , as everybody wants something different - soundbars, amps etc and unfortunately because of this one size doesn't fit all!
