The bass response number looks very poor. Looks like these are meant to be heard with a sub.
Law of physics suggest little bass below 80Hz just like the old ones. Unless they now have a LS50 Tardis speaker. R3/R300 is alway going to be a more rounded speaker, while the LS50 works will in a sub-sat config which configuration wise put's it in another price bracket.Roughly the same as the old LS50. The video review I posted suggests the bass output is absolutely fine though.
If so, is the sound difference much better then the regular KEF LS50 speakers? REL T5i, fabulous subwoofer👍. How do they cope with out a subwoofer? Many thanks.I can wholeheartedly recommend using a sub with the meta’s, I’m using the REL T5i in a medium size room and the pairing is phenomenal.
What would be a good center channel to go with these? KEF used to sell the LS50c which I'm not sure if it was a different speaker or just labeled that way because it could be purchased as a single speaker: KEF LS50C Center channel speaker at Crutchfield
So who’s going to be the first recipient of these Metas? Looking forward to hearing about them.
Looking forward to hearing your findings 👍I am waiting on the colour I want arriving into stock and confirmation that I can get 3. As soon as that happens then me! Will be phoning round a few local dealers in the morning to see if I can get it sorted.
@Paul7777x,
have a pair of KEF LS50's (with the orange drivers) sitting either side of my T.V. and two different friends (non hi-fi enthusiasts) have mentioned how much they liked the look of the speakers.
