I have an OP8 currently but have had Nexus 5, 6P, Pixel 1, & 2.Also, PIxel will get much more timely Android/security updates direct from Google, than any other Android phone.
The OP8 security patches and updates come out like clockwork so far around the 15th of each month.
I do miss some of the Pixel features like the voice mail play back, and I would some of more obscure stuff as well, like the new DUO call waiting thing.
why too early?Is it still too early to jump on the 5G bandwagon, or stick with 4G phone. Want Pixel 5 but it comes with 5G.
Coverage is patchy?why too early?
Switch 5G off then if you want the phone.Is it still too early to jump on the 5G bandwagon, or stick with 4G phone. Want Pixel 5 but it comes with 5G.
Wouldn't the phone be searching for a 5G signal if you leave it switched on, adding battery drain in the process?you don't need to turn off 5g, it just works on 4g etc until you hit a sweet 5g area and then it turns into a unicorn and rainbows come out of its charging ports
I have a OP7T and honestly rather have a pixel again after I upgraded from my original pixel. The software finish from the OP is poor and camera/updates alongside core google features is just lacking. Shall look at getting the Pixel 5 in a couple months after the first batch of stock has gone and prices start to drop.
Oh gosh yes. The size/weight. Weirdly the first week with my 7t my hand had a slight ache and even now it's very top heavy and not natural to hold. Maybe my orignal pixel xl wash just that much lighter and well balanced... Will be interesting to see how the switch back goes as I have the exact same thoughts and certainly don't need a top of the line SoC either.I have a 7pro and i'm moving to a Pixel 5. I'll save this post and give you my honest thoughts. Main reasons for switching
- 7 Pro battery is knackered.
- The size, never really got used to the size and weight (had an s9 before).
- Software updates, I'm months behind and there are bugs they've just not fixed
- Oneplus camera is rubbish, it CAN take good photos but it's slow and inconsistent
- They're moving to a Samsung OneUI OS copy which I wasn't a fan of, I prefer to stick stock.
The phone will be a bit slower but i'll gain waterproofing, wireless charging and pixel updates.
It remains to be seen how much of a difference the SoC really makes as I don't play games. The CPU has the same cores just less of them and clocked a little lower.
Strange why the OP7 battery has had it already. My 3T's is still going strong.
As for photos, OnePlus hardware is capable, but their phone app doesn't do a good job. I'm running a modded Google Camera app on my 3T and the output is much better than what OnePlus' app produces.
Im blaming the fast charging. My other phones under similar usage have lasted fine, this one is always rapid charged and it is bloody fast/hot. Going to charge slow overnight from now on and rapid charge only if required.
I agree with you. I'm on the same page. I also have the OP7T, I chose it because this was as close to having the pixel as I was going to get without having the actual phone. Best believe though just as yourself in a couple to few months I'm getting the pixel 5. I'm happy they brought the rear finger print reader back as wellI have a OP7T and honestly rather have a pixel again after I upgraded from my original pixel. The software finish from the OP is poor and camera/updates alongside core google features is just lacking. Shall look at getting the Pixel 5 in a couple months after the first batch of stock has gone and prices start to drop.
