NEWS: Denon announces X1600H and X2600H AV receivers
Discussion in 'AV Receivers & Amplifiers' started by Phil Hinton, May 22, 2019.
    1. Andy Bassett
      Andy Bassett
      Standard Member Staff Member
      Aug 7, 2017
      249
      46
      Sheffield, UK
      +106
    2. dante01
      dante01
      Mar 5, 2009
      46,341
      +11,132
      So basically the same as the models they replace? That's unusual (not). Current models already have support for both eARC and Airplay 2.
      ARC / eARC COMPATIBILITY
      AirPlay 2 compatibility added to Denon AVRs via software update
      http://rn.dmglobal.com/usmodel/List-Of-AirPlay-2-Compatible-Devices.pdf
      Maybe they should stop trying to imply that such receivers can actually provide 145 watts per channel. There's also the fact that the previous model also had all HDMI ports supporting HDCP 2.2. Ypu'd only ever get 145 watts if powering a single channel at 1kHz while imposing a 6ohm impedance. 2 channel driven will drop the power output down to about 95 watts while all channels will result in you getting well under 50 watts per channel.
      • Agree Agree x 1
      • Useful Useful x 1
      • List
    3. gibbsy
      gibbsy
      May 17, 2007
      13,950
      3
      Cwm Cynon, De Cymru
      +7,831
      The annual merry-go-round begins. Feeling a bit left out now with a four year old 6200.
    4. dante01
      dante01
      Mar 5, 2009
      46,341
      +11,132
      Just change the badge :lesson: :)
      • Like Like x 1
      • Useful Useful x 1
      • List
    5. Jamie
      Jamie
      Jun 27, 2007
      5,360
      2
      Harrogate
      +1,388
      Funnily enough I was just looking at my Marantz 7010 and couldn't find the model. It's there but the font can't be any more than 2mm high. Other than that the 7013 looks identical from the front and I've no doubt the 7014 will look identical too.
    6. Rockets
      Rockets
      Dec 16, 2016
      200
      43
      UK
      +104
      You never know they may get rid of the 'iconic' (as described by Marantz but many people have other words for it) porthole display.
    7. Jamie
      Jamie
      Jun 27, 2007
      5,360
      2
      Harrogate
      +1,388
      Well I like it. Although I also like the fact there's a full display under the flap as well.
    8. series1boy
      series1boy
      Apr 15, 2011
      379
      46
      Sheffield
      +143
      If my x6200 didn’t fail after 2 years of use, and the courier hadn't have lost it, then I would have been more than happy after 4 years. The x4400 I now have is basically the same as the 6200 (without HEOS) which I don’t Use!
      I hope it lasts you another 4 years because it is an amazing amp, which I’m sure you already know :)
    9. AudioWave
      AudioWave
      Mar 31, 2019
      43
      11
      England
      +21
      I think at this point Yamaha has to really step up their game as it seems every year Denon seem to be edging further and further forward while Yamaha seem to be stagnating, still no 11ch Receiver in 2019 although eARC and airplay 2 announced for this year "yay" so my hats off to Denon for pushing forward even if its in small increments.
    10. dante01
      dante01
      Mar 5, 2009
      46,341
      +11,132
      I've a feeling that Yamaha would rather leave it up to the individual owners to add additional amplification as opposed to compromising their receivers by including additional channels of integral amplification? Arcam don't even make a receiver with more than 7 integral channels and there are very good reasons to not keep adding more and more integral channels of amplification. THe vast majority of users don't actually have the space to make use of this anyway so why force them to pay for something they'll not need and that will be detrimental to the overall power output of the unit?
      The "never mind the quality, feel the width" approach isn't always the most desirable or the most cost effective.
    11. gibbsy
      gibbsy
      May 17, 2007
      13,950
      3
      Cwm Cynon, De Cymru
      +7,831
      Got to agree with @dante01 on this. I've got plenty of spare onboard amps to rent out on my 6200 and even then I use a stereo amp for the front pair. I'm never going to be able to support more than 5.1.2 in my current home which I'll only be leaving in the back of a black Merc. The natural progression would be a current 6500 if the 6200 failed but that will have even more redundant amps on board.
      It's fine to have onboard processing but ramming in more and more amps doesn't seem good nor actually needed. Even trying to bare wire and tighten the binding posts is becoming a nightmare because they are so close together.
    12. AudioWave
      AudioWave
      Mar 31, 2019
      43
      11
      England
      +21
      You both make absolutely fair points in regards to the on board amplification and i agree for the most part but maybe I'm just expecting much more from Yamaha as I'm now more invested into the denon eco system after coming away from yamaha but there is no denying yamaha's sound quality which I've said in the past , maybe i should of said Id like to have 11ch's and not need them then need them and not have them :)
    13. Dunners
      Dunners
      Sep 20, 2015
      428
      28
      Close By
      +76
      Regarding 11 channels (or more).
      Having looked inside an 11 channel AVR... there's not much room any more!
      The heat out of them running all 11 channels is clearly going to require fans, which in turn eventually create noise and negative air pressure, meaning the AVR's internals get covered with dust sucked in by the fans... which in turn creates more over heating... even though the fans were designed to stop just this.
      So... yeah.
      I do like Anthem's approach - Class D amplification for channels 8, 9, 10 and 11. Makes a lot more sense!
      In regards to creating new models for 2019...
      Denon / Matantz / Onkyo / Integra / Pioneer have all released (or announced) products... yet none of them have put anything into the market that couldn't be done via a simple firmware update. Their distributors and retailers will be grinding their teeth - but there will be some bargains for consumers looking to pick up old models.
      Yamaha's Airplay 2 firmware update rolled out yesterday (as well as Spotify Connect Free functionality). eARC is on its way... and that will put everyone on an even playing field.
      Well, that's until iMax Enhanced content is available... however I don't think it'll ever challenge Dolby ATMOS in mind or marketshare.
    14. Hixs
      Hixs
      Jul 24, 2015
      3,451
      France
      +2,081
      You've gotta be pretty 'slow' to pay RRP for these knowing they'll be half price in 6 months.
      • Agree Agree x 1
      • Funny Funny x 1
      • List
    15. Broken Hope
      Broken Hope
      Dec 30, 2009
      184
      28
      +54
      I think the only difference is HDCP 2.3, which I don't believe any devices even support and I'm not even sure what's it for, 8K?
    16. dante01
      dante01
      Mar 5, 2009
      46,341
      +11,132
      Yamaha state that all of their current HDCP 2.2 compliant devices also comply with HDCP 2.3:
      https://europe.yamaha.com/files/dow...40/web_VCU3910_HDCP2_3_flyer_All_Multi_A0.pdf
      I don't see why this would be any different for other manufacturers?
      Version 2.3 is simply a reviced version of version 2.2 and does much the same thing.
      We've Expanded Our X-Series Line-up with Two New AV Receivers
      Most of the "new" aspects of the new models that Denon imply are "new" are actually already apparent onboard the models they replace. The X2600 and lower models do get eARC which Denon hadn't bothered to issue updates for the models these models replace. You would have gotten such an update for the X3400 or above though.
    17. anlygi
      anlygi
      Jul 21, 2010
      521
      3
      46
      Belfast
      +176
      That's attitude is how you end up with a new AVR whether you need it or not!
    18. dante01
      dante01
      Mar 5, 2009
      46,341
      +11,132
      or how you end up sat on a merry go round eating a croissant wondering how the hell you got there????
      • Like Like x 1
      • Agree Agree x 1
      • List
    19. Gasp3621
      Gasp3621
      Jan 16, 2014
      1,815
      116
      +880
      X1500H and X2500H doesn´t have eARC support, the model comparison at Denon UK site shows that. Also the link you provided mentions:
      At same timing (1st half 2018), we will issue a firmware update for the following HDMI 2.0 compliant models to achieve eARC compatibility:
      AVR-X3400H, AVR-X4400H, AVR-X6400H, AVC-X8500H
      X3600H will be introduced later on June/July, but no new 4000/6000 models this year.
    20. dante01
      dante01
      Mar 5, 2009
      46,341
      +11,132
