NEWS: Apple AirPods Pro to ship from 30th Oct for £249
meagabyte
Always wanted a pair but i just cant justify that price tag.
Earthscope
Placed my order today 🎧
Great addition for my 12.9 iPad Pro :D
Tristan45
I’ve got gen 1 AirPods
are these worth the upgrade?
bbasra
Also ordered - mine shall be arriving tomorrow.
Sebastalona
Read the article in the first post, more than enough information for you to judge whether these will be a worthwhile upgrade.
Hillskill
Moderator/Games Reviewer
Can the ear tips be swapped for complys?
Steven
Senior Moderator
Even if the answer is "no" I would be reasonably confident comply, spinfit and non-branded would develop and release a new tip. £$€ talks :-D
boltlock
Just need JL to get stock, still get discount on Apple accessories so will be worth the extra wait. Hopefully I'll be able to use them when running without the need for silicone ear grips unlike the gen 1 and 2 AirPods
You’ll definitely be able to go running in these mate. Luckily they fit me perfectly, straight out of the box but I’ve had no issues with them coming loose whilst walking, talking or eating.
flashf1
Is there anyone that couldn't get a good fit on the gen 1 & 2, would slip out, come loose etc, but these are fitting ok?
JayCee
I'll definitely consider these if audio quality reviews are good and after market foam tips are available eventually.
boltlock
That’ll be me then. I had a lousy time with the original ones except when my ears got wet, after which the ‘pods would seem to get more grippy but still not infallible. The new ones however, stay in in regardless of what I do.
Btw if anyone thinks the volume level is too low, just go to settings,music and turn off sound check. This makes them that bit louder without any noticeable loss in quality. Well, none that I can detect at least.
swall101
Anyone able to give review of sound quality?
interbear
Picked mine up today too and so far very impressed with the fit and sound quality. The Active Noise Cancelling is great. I’ve used Bose QC20s for years for noise cancelling when travelling and find that they create a strange pressure in the ear that I can only live with for a limited amount of time. I didn’t get this at all with the Airpod Pros so that’s a big positive too.
My original AirPods have been redistributed to my daughter. She’s happy. I’m happier. Initial impressions are that the AirPod Pros are a big upgrade on the originals in just about every way. I also like the design / smaller “stem”, look a little less daft than the original AirPods. Not tried phone calls yet but for music, very good indeed.
Mr X
Mine came this morning in time for a tube ride across London and then a train to Reading so an ideal testing day.
I’ve used a few noice cancelling on ears before and various high quality in ears such as £1000 Shure 846
I’ve also come from the AirPods 2 and though I liked them I had to use silicon aftermarket tips to keep them in and improve sound quality/seal.
They are really good but a pain to carry around.
Anyway 2.5 hours in ear and no ear fatigue.
Unlike normal in-ears there’s no stalk just the clever tips so maybe this helps. The controls on the air pod Itself was a little fiddly at first but go used to that.
The killer feature for me is the noise cancelling. Really effective and for the first time no real vacuum sense thanks to those little vents.
Also walked through a really windy tunnel at Oxford Circus and only noticed slight wind noise when my track stopped but again no vacuum.
Transparency is also a great feature and means I will probably leave them in ear a lot of the time (I receive a lot of phone calls which was actually my main reason for buying the AP2)
So for me this is almost the ideal product - I just really would have liked nice colour option other than white.
swall101
Many thanks for the review. In regards to sound quality how would you say it faired against wired IEMs of a similar value. I have a set of Phonak Audeo PFE 232 (appreciate these are of a higher value) but like the convenience of wireless... cheers
Mr X
Thats a tough one as I haven't used wired IEMS for quite some time as sold my Shures 846 about a year ago and I used them via my Chord Mojo/Poly - I also don't think my ears are as good as they used to be now!
At home I use B&W P7W's and Oppo PM1's via the Mojo. Whilst the AirPods Pro can't compete with them, they really are pretty impressive. If I try and remember what my 846 used to sound like on the tube, they used to be pushed very far in my canal and volume cranked way up to cut out the background noise. The AirPods Pros and the N/C really do a great job in this environment.
If fly in 2 weeks and today sold my Sony WH-1000XM3's on the forums so will be interesting to see how the AirPods cope on long-haul!
Today I got an even better seal by changing the tip which improved the bass so I think you won't be disappointed if you get the fit right. The good thing is that buying from Apple essentially means you've got a 14 day no quibble home trial so that's what I would do.
Hillskill
What tips did you change to?
swall101
Hillskill
Been trying to discover if they will use aftermarket tips. I used to love complys back in my IEM days
Inked
Just picked mine up and they are a really nice upgrade from Gen 1 & 2 due to the noise cancellation and better fit (I surprisingly felt most comfortable with the smallest tips and get a good seal with all sizes according to the software)
I asked my wife to try them and got the “for flips sake, what’s so special about a set of AirPods?” look from her (she has some gen 1). Right up until I turned on the noise cancellation and the dyson fan she was stood next to went virtually silent in her ears! 😂
They still sound like AirPods so I’m sure there are better sounding headphones and earphones out there but the integration with iOS and the fact I’m not keen on over ear headphones make these just about perfect for me.
SimonB91
Anyone who has purchased the new AirPod Pros - How do they compare to the Cambridge Audio Melomania 1’s? Torn between the two, with price being one of the factors - although the iOS simplicity and active-eq of the AirPod Pros are causing me to lean towards them.
Getgaff
I’m not getting on with these at all. Tried the medium and small tips and both are equally uncomfortable (large is too big for me). And whereas my Gen1s were unobtrusive, I’m just so conscious these Pros are jammed in my ears.
I’ll give it another day or two but my gut feeling is these are going to end up on eBay over the weekend.
Trending threads
Latest news
Disney+ hits 10 million subscribers after first 24 hours
  • By Andy Bassett
  • Published
Sharp unveils 30-inch rollable OLED TV
  • By Andy Bassett
  • Published
ATC launches C1 Sub Mk2 active subwoofer
  • By Andy Bassett
  • Published
Best Home AV Products 2019 - Editor's Choice Awards
  • By Steve Withers
  • Published
Disney+ unveils Maclunkey cut of Star Wars: A New Hope
  • By Andy Bassett
  • Published
Latest threads
