Newbie
Discussion in 'Arcam Owners' Forum' started by dboo, Sep 14, 2004.
Tags:
  1. dboo
    dboo
    Sep 14, 2004
    28
    I wish to acquire my first home cinema gear. I am confused. What is the difference between an AV processor and an AV receiver? Which do I need? While I enjoy watching DVDs, I suspect listening to music turns me on more. Can you recommend a package for me to buy with a budget of betweem £3K and £4K. Thanks.
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    1: An AV processor is a box that decodes the digital signals sent from a DVD player and decides which sounds go to which speakers and when. The decoded signals from an AV processor have to then be fed to a multi-channel amplifier whcih will drive the speakers.
    2: An AV Receiver is an AV Processor and a multi channel amplifier in one box. The 'Receiver' part of the name indicates it also has a radio tuner built in.
    3: A good start for £3-4000 would be the Arcam DV79 DVD player (£1000)and the AVR300 AV Receiver (£1300). This would leave a suitable budget of about £750-1000 for a decent subwoofer and about £1000-1250 for a 5-7 channel speaker package.
  3. Radioactive__Man
    Radioactive__Man
    Jan 13, 2001
    967
    Scotland
    +18
    If you are a female let me be the first to offer my services in setting it up for you [the audio side anyways] :)
    If you are a bloke, I was never here, and the above statement was never issued :suicide:
    p.s. as of this Friday I wiil have practically that very setup
  4. dboo
    dboo
    Sep 14, 2004
    28
    Thanks for the info.
