Newbie - Which Freeview box?
Discussion in 'Freeview & YouView' started by compact, Sep 11, 2007.
  1. compact
    compact
    Aug 1, 2007
    67
    9
    Never had freeview. I did think about just getting the cheapest box, until I saw my friends different systems and different menu's.
    So which box do you recommend?
    I have a Philips DVP 5960, a crt widescreen tv I inherited (not that great).
    Looking for a cost effective solution, but with a nice, quick, easy to use menu.
    CHeers
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,733
    Somewhere in South Yorkshire
    +6,311
    Does your TV have any kind of auxiliary (or "Ext") input for video and audio- such as SCART or RCA phono sockets?
  3. compact
    compact
    Aug 1, 2007
    67
    9
    Cheers for the reply.
    The tv isn't as bad as I make it sound.
    I think it's a Goodmans, widescreen with 2 scart and the 3 RGB connections.
    Are freeview with card slots (for santana or sky) a lot more expensive?
  4. fernandez
    fernandez
    Jun 5, 2005
    6,039
    +995
    Freeview receivers will the necessary embedded CAM for Setanta seem to be around the £40 - £50 price range.
    A Sky card will not work in any Freeview receiver - different system completely.
    And BTW - it's SE-TAN-TA not sultana or banana or santana:rolleyes::D
  5. gaz010
    gaz010
    Sep 5, 2007
    41
    And as most ex customers now call them the :devil:
