Newbie WHAT SCREEN IS BEST
Discussion in 'Projectors, Screens & Video Processors' started by jimmyfixit, Oct 12, 2004.
  1. jimmyfixit
    jimmyfixit
    Im getting a screenplay 4805 which is going to be mounted on a shelf high on the wall. I want the screen to be electic and at least 6ft poss 8ft, so what one would be best???
  2. mojomanic
    mojomanic
    I have the 4805 pj and am projecting onto a Drh slimline 240 electric screen, 80inch wide with superb results
  3. Braveheart
    Braveheart
    I also have a 4805 with projector mounted on wall. I also will give a vote of confindence for the DRH, although I went for a manual 5.5 ft and a unity gain.
  4. sanj
    sanj
    Oct 24, 2002
    Newport
    +8
    I have a Z2 and a DRH slimline 8ft electric screen and I recommend them
    as well. I've had the screen for approx. 4 months and had no issues with them at all!
  5. jimmyfixit
    jimmyfixit
    thanks alot for your help :thumbsup: Im new to all this, what is the diferance in screen types i.e. high power etc, and what type would go well with the 4805 pj, once angain many thanks :)
  6. mojomanic
    mojomanic
    My screen is a matt white with a screen gain of 1.0 and it suits the 4805 just fine!!
  7. Braveheart
    Braveheart
    jimmyfixit
    Basically, some screens reflect more light than others. See DRH screens website for details or checkout Stewartscreen's website. It will give you a good idea what type of screen you need.
    If you have a lot of ambient light in your viewing room you may need to have a high power or high gain screen(reflects more light). On the other hand you make have a very dark viewing room you may go for a lower gain screen i.e 1.0 gain
    I decided on a DRH 1.0 gain screen and also use a 4805 wall mounted PJ. Contacted DRH screens and they sent me some samples.
  8. jimmyfixit
    jimmyfixit
    :offtopic: Big up all those who post on such a great site, your all so helpful, keep the good work up peps :thumbsup:
