Newbie - What exactly is a HCPC?
Discussion in 'Desktop & Laptop Computers Forum' started by trivisingh, May 8, 2003.
  1. trivisingh
    trivisingh
    I am a newbie to home theatre systems and I will putting one together soon. I want to know what is a HCPC or HTPC. Is it a computer with some special equipment or can any PC be used for playing DVDs. Can I use my PC with an ASUS DVD ROM and Geforce card for playing DVDs on the Sony HS10 projector. Also which cable do I use to connect the PC to the projecter (I guess the same RGB cable which goes to the monitor can be used) Also since the HS10 is a widescreen projector how do I get the DVD picture from the PC to fill the whole screen.
    I would also appreciate if someone can give me a list of hardware and software to put together a HCPC
    thanks
  2. Underscore
    Underscore
    An HTPC can be any PC - it's more about what it's used for - though it will often contain components selected to be particularly quiet. I'm sure you can start with your existing PC and see how you get - yes, a VGA cable is fine, though I think the HS10 can use DVI? To get the correct resolution to allow you to fill the HS10 panels without using the internal scaler, you need to use a tool called powerstrip, which will allow you to add custom resolutions and, if necessary, refresh rates - there should be a link in one of the stickies.
    To give you an idea of what I think is a fairly standard HTPC, this is the spec of the HTPC which I just built:
    Hardware:
    Antec 660AMG case with Trupower330 PSU
    Athlon XP2100+
    Zalman 6000Cu Flower cooler
    512MB PC2700
    ASUS A7V8X mobo
    Creative SB 4.1 Digital for S/PDIF out
    Sapphire Radeon 9000 64MB VGA/DVI/TV
    Nebula DTT card
    Seagate Barracuda V 120GB
    Pioneer DVD-120
    Software:
    Win2kPro
    TheaterTek DVD
    DVDRegionFree
    Reclock 0.99j
    ffdshow (though current not using)
    HTH,
    _
    [Edit: added case to h/w list]
  3. Branxx
    Branxx
    Nov 1, 2000
    810
    London, UK
    I posted my new HTPC configuration here, which should be capable of playing the new Terminator 2 Extreme Edition in high-definition.
