Newbie wants freeview in bedroom!
Discussion in 'Freeview & YouView' started by Basil65, Jun 20, 2005.
  1. Basil65
    Basil65
    What I want to do is have my freeview box in a remote location and control it in the bedroom. I have co-axial cable already installed from one location to the other. Will the co-ax suffice? How can I remotely control the digi-box? is there a better alternative?
    Enough questions for now I think. Thanks to anyone who replys in advance, thank god you're out there!!!
  2. Dr Diversity
    Dr Diversity
    There are boxes you can buy from Argos and the like that allow you to do this. All works down the co-ax and you have your remote control for the freeview in the bedroom. Doesn't behave very well through splitters though, try to keep the circuit simple
  3. bobcar
    bobcar
    Oct 3, 2004
    708
    +21
    It would help in giving an answer if you could explain why you don't want the freeview box in your bedroom. This would give the best results from a picture quality point of view and is also the cheapest method.
  4. HarryAlffa
    HarryAlffa
    Jan 6, 2005
    61
    I don't really have an answer, but to be clear, like the last poster implied; I assume in the other room the Freeview box is attached to a TV (via scart for good picture quality) but you want to take advantage of the RF modulator-out on your Freeview box by sending it into your bedroom? And thus want to control it from both rooms?
  5. HarryAlffa
    HarryAlffa
    Jan 6, 2005
    61
    Only if your Freeview box sends its picture out through the ariel connector. Some only send their picture out through the scart connector.
  6. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    Put a cheap FV box on the bedroom TV
  7. Richard46
    Richard46
    Oct 15, 2000
    1,796
    63
    London E7 UK
    +120
    With Freeview STB's at £30-£40 thats got to be the way to go, much simpler. Sounds like you already have the co-ax to feed the 2nd box so you just need a splitter.
