Newbie, VSM2048, PSM, Faroudja
Discussion in 'Projectors, Screens & Video Processors' started by TT9, Jan 13, 2004.
  1. TT9
    TT9
    Greetings,
    Two motives to this question - I am trying to educate myself this year with the technical issues and motives in visual and audio aspects, and I want to get the best picture possible.
    So. . . .
    I am trying to achieve the very best picture quality I can from my system. I have a DVD32R which is outputting an interlaced signal to my Domino30. This is de-interlaced/scaled by the Faroudja DCDi chipset. This is correct ? Connection is component.
    Now, would I see a difference in quality if I included in the loop the Tag PSM and VSM modules ? The PSM would take care of de-interlacing, and the VSM scale to a 1280x720 resolution. I suppose the question is, as the Tag components will be replicating the job of the Faroudja chipset, are these better in that they will provide a better picture quality. The whole idea of letting the projecter scale/deinterlace or moving it to the source is one which is confusing me.
    Can somebody provide some insight to a lost little chap !?
    Thanks and regards,
    Steve.
  2. Miron
    Miron
    Sep 26, 2002
    1,428
    Vienna, Austria
    +53
    Steve,
    how about checking it yourself.
    If you are ready to spend so much money then there should be dealer ready to offer you decent comparison.
    There is no way around this
    Regards
  3. TT9
    TT9
    HI Miron,
    And thanks for the reply.
    If only it was so simple getting hold of these components to be able to experiment for a while. The PSM requires insertion into the DVD of course and the scaler would mean me getting my hands on the AV192.
    Failing anyone being able to give a first hand opinion of the PSM and VSM I was hoping for some feedback on the differences between de-interlacing at source and the within the projector.
    Thanks and Regards,
    Steve.
  4. GaryG
    GaryG
    Nov 20, 2002
    744
    Shropshire
    Steve
    I'm not able to give you a complete answer but may give you food for thought.
    I have a DVD32 FLR fitted with the PSM192. I also have a Faroudja NRS scaler. Comparing the NRS to the PSM192 (an apples to oranges comparison because of the different resolution) the NRS gives the better picture with more vibrant colours.
    I spoke to Alan Roser (UK Sim2 distributor) yesterday about using the NRS into a Sim2 projector in preference to the internal Faroudja scaler, he said that I would get a better picture from the NRS due to it having a better colour decoder.
  5. cj
    cj
    Apr 6, 2001
    1,460
    Reading
    +74
    Hi Steve,
    I know my local dealer is waiting on his his VSM module to return from Tag, and they'll be running it connected up to a Runco CL-710 which is the same resolution as your Sim2.
    Cheers,
    Colin
  6. TT9
    TT9
    Cheers col,
    Give me a shout when he gets his mits on in. I'd be interested in a before and after comparison if you are abl to do one. . . or failing that I might drag myself around the M25 and come and see for myself !
    I tell you what, for a fully loaded AV192, PSM, VSM the lot. . . . how much . . . ?:eek:
    I think even with my thrifty :devil: attitudes I may have to bale on that one !!
    Steve.
  7. cj
    cj
    Apr 6, 2001
    1,460
    Reading
    +74
    Yeah I've been thinking about it myself, but you're probably talking around £15,000 new or £11,000 second hand which I think even I'd struggle to get past the missus without selling another one of my motorbikes, or maybe one of the kids...
    As much as I love Tag gear (and would love a fully loaded AV192 + VSM2048), I think common sense will prevail this time and I'll buy an external scaler and save myself £10k.
    From what I've gathered any sort of reasonable external scaling is going to be better than the projector scaler (why? I'm not sure either...). I've been playing with a PC hooked up into my CL-710 (via DVI) against my DVD32 + PSM192 via component and picture wise you'd definitely be happy with the HTPC (of course the PC is outputting at 1280x720, which the PSM192 doesn't).
    I'll let you know when I've seen the VSM in action.
    Colin
  8. parky43007
    parky43007
    Oct 8, 2003
    235
    Tarragona
    +16
    There was, the other day, a fully loaded AV192 ex demo on the Sevenoaks website (in Bristol I think) for around 6 grand. Obviously this would need the VSM adding but would come out at less than 10 grand.
