peckhampleb
Hi. Haven't used a forum for years so Hi all and I hope you don't mind if I get straight to a question of transferring my titles from one Sony hdd dvd rec to another even older model. The 870 had been excellent but no longer will transfer recordings to a blank disc so I decided to purchase a used recorder, the freeview-less 350 but pleb that I undoubtedly am, cannot manage to do this though I have done in the past using different machines.
It's quite possible the leads are not correctly connected. I have one end of the (composite?) yellow, white and red connectors attached to the 'line out' of the 870 and the other end in the 'line in' of the 350. Good so far? If so what other leads/connections are necessary to accomplish the transfer and would I be able to monitor what's being transferred via the 350? If that's as clear as mud, my apologies. Cheers
