AndySound87
Hi everyone. Thanks for taking the time to read and help. So for 3 weeks I have been pulling my hair out everyday looking into getting a projector for my bedroom.
There is SOOOOOOO much to take into consideration and there are SOOOOOO many projectors out there is mind boggling. Essentially I have a throw distance of 3m.
but I don't want to get a projector that's limited to that either. I have a shelf installed ready for said projector. The room I have on my wall at the moment is 70 inches wide. But I would also like to be able to use this on the side of my garage which is painted white and is substantially bigger than the bedroom wall space. Budget is anything under £1000. I think my throw ratio is 1.7?? So questions...Is it worth investing in the 4k pixel shifting? Is 1080 native enough? Do I get DLP,3LCD,LED? I would very much appreciate any advice on what projectors I should be looking at. I have my eye on a few . 2 from Epson and one from Benq. Fan noise is quite important as I have quite sensitive hearing. I the rainbow effect something I should worry about in DLP projectors? Essentially I want something that is quite flexible too. With some lens shifting options. I know keystone is not advised as it effects res or something? Anyway , please send help. Many many thanks.
