Newbie to Freeview needs help choosing a box!
Discussion in 'Freeview & YouView' started by Unlight, Jun 23, 2004.
  1. Unlight
    Unlight
    Jan 6, 2003
    1,524
    38
    Belfast
    +9
    Hey there,
    Im having trouble choosing which Freeview box is best to get. I dont want Sky as I dont watch all that much TV, but Ive heard that Digital TV is obviously better picture quality (im fed up with rubbish reception on analogue).
    Can anyone recommend a good one? Ive only got a Phillps 28" flat widescreen, but hoping to upgrade to a panny plasma over the next month or so :)
    Thanks in advance! :)
  2. steverb
    steverb
    Jun 11, 2004
    89
    I just upgraded my Freeview box to a Pace Twin. The hard disk provides brilliant recordings and I can now chuck out my VCR.
  3. Unlight
    Unlight
    Jan 6, 2003
    1,524
    38
    Belfast
    +9
    Ahh yes I forgot about HDD recorders sometimes having a tuner built in -
    Nice to hear youre happy with the Pace, where abouts did you get it?
  4. matty2767
    matty2767
    i have the sony one. it looks great and has two scart outputs, rf loopthrough and an optical out. it also changes channels very quickly and since i have had it has only had slight artefacting twice.
  5. sparkybun
    sparkybun
    Jan 6, 2002
    1,253
    41
    EN8 area
    +24
    Humax PVR8000T - 40Gb hard disk (twice the size of the Pace) seems good value at approx £135-£140 from various online stores. They are soon to bring out the PVR9000T which has twin tuners and a removable hard disk cartridge.
    Mel
  6. steverb
    steverb
    Jun 11, 2004
    89
    Unlight,
    I got the Pace twin for £182 from Digitaldirect, including delivery. They seem to go on Ebay for about £160, but £182 for a new one, was a no brainer.
  7. DDave
    DDave
  8. Unlight
    Unlight
    Jan 6, 2003
    1,524
    38
    Belfast
    +9
    So i should go for the Pace then?
    Im thinking of going out and getting one from Argos for £199, seeing if i like it - if not, return it, if i do - return it and buy it online :)
  9. Kevo
    Kevo
    Aug 23, 2001
    5,424
    Manchester
    +158
    That's a bit naughty isn't it.
    Is it really worth all the hassle for the sake of a few quid?
    What if you have problems with it and you have to send it back?
    Will the on-line retailer be as forthcoming as Argos?
    By all means try and get to see a demo of it from somewhere and ask if they'll price match on-line, but to use them in this way is well dodgy.
    It's your choice but I have no sympathy for you if all goes wrong.
  10. Unlight
    Unlight
    Jan 6, 2003
    1,524
    38
    Belfast
    +9
    It was light hearted mate :)
    I'll probably pick one up from argos at the weekend, couldnt be bothered with the hassle of returning it and waiting for the delivery of a new one :)
  11. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    :thumbsup: 532/0228 :thumbsup:
  12. sparkybun
    sparkybun
    Jan 6, 2002
    1,253
    41
    EN8 area
    +24
    If you're worried about the twin tuners - get the Humax which is double the size of hard disk and another freeview box. Should work out about the same or even cheaper than the Pace. Alternatively hang on for the 9000T which has twin tuners and removable hard disk modules.
    Mel
  13. sparkybun
    sparkybun
    Jan 6, 2002
    1,253
    41
    EN8 area
    +24
    Forgot to mention the Thomson DHD4000 which has twin tuners and double the hard disk of the Pace BUT is £249.
    Mel
  14. Unlight
    Unlight
    Jan 6, 2003
    1,524
    38
    Belfast
    +9
    Thanks for the info! When is this 9000T coming out? Sounds good!
    Saw the Humax yesterday and didnt like the look of it at all!
  15. FruitBat
    FruitBat
    Nov 15, 2003
    3,303
    Ealing
    +379
    I was in the same position a week ago.
    I decided that what I wanted was HDD recorder plus twin tuners plus PC connectivity. The Humax 9000 seems the nearest (removable disks) but is not available yet. So I got the cheapest box with good reviews to be going on with (Pioneer DBR-TF100 for 70 quid).
  16. sparkybun
    sparkybun
    Jan 6, 2002
    1,253
    41
    EN8 area
    +24
  17. nealb
    nealb
    Nov 15, 2002
    194
    +5
    I got a Netgem box about a month back. Excellent. Only cost me about £55 from Makro... Can even plug it into a LAN / WiFi network to go online with.
    Speed, picture and sound are all first rate.
  18. rOAdeh
    rOAdeh
    Jan 24, 2003
    648
    Winchester
    +5
    sparkybun, that article was published over a year ago and the main reason for the recent delay is that humax decided a few months back to redesign certain aspects of the 9000t to meet with new customer demands so i think there could be some quite significant changes.
    I emailed humax yesterday with regards to the release date of the 9000t and shall post here if and when i receive a reply. for the time being though, given that funds are tight i've decided not to go for a pvr atm and will probably go with the humax fox box since its now availabe for a rather nice £60 :D
  19. PhilipVass
    PhilipVass
    The Goodmans GDB4 is a good box, no card slot but i am assuming you don't want a subscription, the processor is one the the fastest around. Only £50 in Richer Sound and Argos.
  20. rOAdeh
    rOAdeh
    Jan 24, 2003
    648
    Winchester
    +5
    As promised here's the reply i got from Humax:
    So disappointingly it's still another 6 months away at least - particularly if you want the option to have TUTV support (though arguably that may not be such a priority by then dependent on it's success in the next few months and/or a seperate attachment might well be obtainable to provide support)
    As i said before i've just gone for their standard Fox2 freeview box, which should be here tomorrow :D, namely because i have no money but this email has also helped reduce the feelings of what if :)
    hope that helps someone who was in a similar position to me
