newbie to dvd recording
Discussion in 'Blu-ray & DVD Players & Recorders' started by bludger, Apr 24, 2007.
  1. bludger
    bludger
    Hello All,
    I have a Philips analogue television and a Humax digibox for Freeview. If I buy the Toshiba RD XS24, which seems to be good value, will I be able to:
    record one Freeview programme while watching another Freeview programme?
    record a Freeview programme while watching a non-Freeview programme?
    tolerate the noise of the fan?
    find the machine reasonably easy to use?
    Another point is that I couldn't seem to find if the Toshiba has an EPG.
    If anyone has any other suggestions to make, I'd be grateful. I don't need High Def or anything fancy.
    Best wishes.
  2. JayCee
    JayCee
    Jan 20, 2004
    23,768
    Lanarkshire
    +2,572
    As far as I know the RD-XS24SB does not have a DVB (Freeview) tuner...Analogue only...so you could record a Freeview channel from your Humax and watch Analogue from your TV...but you cannot record one Freeview channel and watch a different one.
  3. bludger
    bludger
    Hi Jaycee,
    Ah, that explains why the model is going pretty cheaply. I'll have to do some more research.
    Thanks for your help.
    Bludger
