M
mykaloon
Just unpacked my newly delivered Mordaunt Short 309 subwoofer and have connected it up to my amp and nothing's happened - thought it would be a case of plugging in and you'd get some sound which would need to be tweeked - but nothing....
Here's a list of what I've bought and connected up so far...
Sony DVP-NS355 dvd player connected to Sony STR-DE497 amp using a Profigold PGD483 cable. Then connected the subwoofer to the amp using a Profigold PGA4105 sub woofer cable. Only problem here is that I've connected the sub cable to the audio out sub woofer on the amp but the sub has inputs for speaker cable and also L and R inputs under the heading LINE IN with an in and an out section. Problem is the interconnect I have only has one plug - not two for going into a Left and Right.
Anyway, have been into the menu on my amp and reset it back to factory settings with no change.
I've checked and double checked all the connections with nothing appearing loose.
Any pointers or advice would be greatly appreciated.
Thanks in advance
Mykaloon
Thanks in advance
Mykaloon
