Newbie stupid question no. 9
Discussion in 'AV Receivers & Amplifiers' started by UselessPratt, May 7, 2003.
  1. UselessPratt
    UselessPratt
    Okay, I know I keep asking stupid questions, but that's what a forum's for, isn't it?
    If I buy an AV amp that supports 7.1 do I HAVE to have all the speakers? I mean I only want a 5.1 set of speakers to start. Should I just buy a 5.1 amp then??
  2. Jase
    Jase
    Mar 16, 2001
    9,469
    South Coast
    +893
    You don't have to connect all the speakers to an amp that supports 7.1. I would say it's better to purchase an amp with 6.1/7.1 decoding & amplification then you have the option to add the additional speakers at a later date.
  3. UselessPratt
    UselessPratt
    Sounds good. ( Excuse pun )
    So you just tell it you only have a 5.1 speaker setup or doesn't it care?
    ( I guess I will find this out when I actually buy an amp!)
  4. Jase
    Jase
    Mar 16, 2001
    9,469
    South Coast
    +893
    You usually have to select which speakers you have in the Setup Menu with the minimum being the two front left & right speakers. Then you select, Centre yes/no, Surrounds yes/no, Sub yes/no etc etc then you'll move onto whether they are Large or Small etc etc (that's another story!).
  5. UselessPratt
    UselessPratt
    That worries me! How easy are they set up? I mean I know that some offer auto setup now.
  6. nathan_silly
    nathan_silly
    Yes some automatically plug themselves in.
  7. Jase
    Jase
    Mar 16, 2001
    9,469
    South Coast
    +893
    I'd say they are pretty easy to setup but I'm fairly used to them now, intially they make look a bit daunting. If you're worried then maybe go for one that has a completely automated setup like some of the Pioneer's (VSX-2011 etc).
  8. UselessPratt
    UselessPratt
    As long as you tell me its simple, then I am sure I'll get used to it! :)
  9. Sunday Ironfoot
    Sunday Ironfoot
    My flatmate bought an AV amp that came in a box with a button on top. You pushed the button and it automatically unpacks itself, walks over to your HIFI rack, sits down and automatically plugs in all the wires, great stuff! :D
  10. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    This is a general "problem" and has nothing much to do with using 5 or seven speakers, so in any case you have to face it.
    With a bit of patience (and perhaps some help here in the forum) you should be able to do it! :)
  11. UselessPratt
    UselessPratt
    Thanks everyone...
    The entire setting up process will be easier, now I know what to expect!
