I'm after some help on the best way to connect my amplifier to my speakers and sub.
I have just bought:
Yamaha RXV483 - Yamaha RXV483 (Black)
Canton Movie 75 - Canton MOVIE 75 (Black)
QED Silver Anniversary speaker cable QED SILVER ANNIVERSARYxt
The speaker cable is too thick to fit into the holes of the speakers.
I'm guessing using Banana plugs is a better idea to connect to the amp? Are these easy to fit to the wire?
What's my best option to connect to the speakers? Ideally, I need like a mini banana plug with a 90-degree fitting to get into the hole.
Also, the current way I've connected the sub, is this ok or is there a better way?
As you can tell this is my first time at doing this!
Any help appreciated.
I have just bought:
