Newbie soundbar guidance please
Discussion in 'Soundbars, Soundplates & Soundbases' started by wheelnut, Dec 8, 2017.
Tags:
  1. wheelnut
    wheelnut
    Dec 2, 2012
    3
    Some advice please.
    I am looking to buy a budget soundbar / soundbase and have narrowed it down to two models:-
    Panasonic SC-HTE80 Soundbase
    LG SJ2 Sound bar with wireless sub.
    The Panasonic has HDMI ARC and whilst my TV does not have a ARC HDMI port (just old HDMI and optical), that would give me a degree of future proofing for when I change the TV.
    The LG has optical only input but I think I would probably prefer the effect of a separate sub woofer.
    The reason for choosing these models is partly because of physical space constraints and also that they are both at Argos and I can pay for them using my Nectar points!!
    Which (if either) would you buy? I mainly just watch TV, but I will use the bluetooth for music as well.
    Thanks in advance for your advice.
