Newbie, silly question
Discussion in 'AV Receivers & Amplifiers' started by joncycle, Jan 10, 2008.
  1. joncycle
    joncycle
    Jan 4, 2008
    59
    Benicassim, Spain
    +3
    Ok, silly question but I have to ask it.
    If I plug the phono sockets from a Sky Digi Box into a AV Amp will it then produce surround sound for me through a 5 speaker set up?
    I am after just a simple and cheap solution for a VERY basic surround sound effort for a living room in my second house.
    thanks
    Jon
  2. Andy98765
    Andy98765
    Feb 15, 2006
    10,472
    2
    +1,365
    It will send stereo to your amp and if your amp (Should have) has got Dolby Pro Logic you will get sound out of all the speakers.
  3. joncycle
    joncycle
    Jan 4, 2008
    59
    Benicassim, Spain
    +3
    Hi Andy,
    so when buying the amp i should look for dolby pro logic in the list of specs?
  4. Andy98765
    Andy98765
    Feb 15, 2006
    10,472
    2
    +1,365
    Simple answer is "YES", but then again 99.9% have anyway.
    What were you thinking of buying, hopefully not a all-in-one?
    If you had SKY+ or HD you get a optical out and dolby digital on movie channels etc.
  5. joncycle
    joncycle
    Jan 4, 2008
    59
    Benicassim, Spain
    +3
    not sure to be honest, was thinking of having a look around, maybe go to richer sounds next time i´m in the UK, they are always pretty good in the past. Or any other ideas online, for a cheap setup?
  6. Deadstar
    Deadstar
    Jan 10, 2008
    20
    That is about the same silly question I wanted to ask.
    I have a Denon AVC amp. Can I just get Dolby surround by plugging 2 RCA plugs from my DVD-player to my amp? Or do I need a special cable?
  7. nero0410
    nero0410
    Jan 5, 2004
    12,666
    Weston Super Mare, UK
    +5,005
    You canachieve dolby 'pro logic' surround by using just the rca plugs, but your best bet for a dvd player would have to be a digital coaxal, or optical cable depending what connections you have on your dvd player which will give you the proper dolbydigital/dts 5.1
    tris
  8. nero0410
    nero0410
    Jan 5, 2004
    12,666
    +5,005
    Give an an idea of what you are wanting to spend, and we can go from there
    tris
