Newbie set up help please...
Discussion in 'Home Cinema Buying & Building' started by pmlk, Feb 12, 2009.
  1. pmlk
    pmlk
    Feb 12, 2009
    4
    Hi all!
    I have a LE4OM8/LCD TV
    PS3
    V+ box
    Sony multi channel av receiver str-ks1300.(3 hdmi in/1 hdmi out)
    At the present i have hdmi out to tv and ps3 and v+ hdmi in to receiver sound is ok..? is it worth using a audio cable as well? All help appreciated...
  2. dwhite
    dwhite
    Dec 13, 2001
    7,414
    Whitehaven
    +1,805
    As this appears to be the receiver that comes with the HTSS(F)1300 all in one package, I shall move this thread to the all in ones forum. Plenty of discussion on the Sony 1300 already in there.
  3. cols
    cols
    Sep 5, 2008
    3,338
    Colchester
    +517
    Hdmi already is an audio cable, and a better one than optical.
    Optical gives dd and dts, and 2ch pcm. Hdmi gives dd, dts, dd+, dthd, dts hd ma, and multichannel pcm.
    Your connections are correct - ensure ps3 is set to output lpcm over hdmi in video settings, and redo your ps3 sound settings - auto works fine. You'll then get dd / dts / dd+ / dthd / dts hd ma from your ps3.
    Don't know about virgin boxes and whether it outputs 5.1ch over hdmi - you might want to check the satellite forums for that. I know with sky an optical cable is needed as they don't output 5.1ch over hdmi, only over optical.
