Newbie resolution question
Discussion in 'Plasma TVs' started by DaveP, Sep 8, 2005.
  1. DaveP
    DaveP
    I tried a search but nearly every thread seems to mention resolution at some point!
    My question is: Is there a PDP that has a resolution of 1280x720, 1366x768, 1280x768 or any other PC based widescreen resolution?
    I've got used to 1280x768 on my 26" LCD but I'm now looking to replace my 36" Sony CRT with a 42" screen. All the plasmas I've looked at have odd shaped pixels and I really want to connect my PC to this as well as the usual things like Sky, DVD player etc.
    Has anyone connected their PC to a 42" screen and if so what res are you running. I get 1:1 pixel mapping on the LCD but it looks like I won't be able to achieve this with a plasma. Surely running 1024x768 on a w/s plasma panel will give odd shaped circles and short fat people!
    Dave
  2. bishman
    bishman
    Mar 29, 2001
    4,902
    83
    hertford
    +172
    I don't think there are any plasmas that have your required native resolution. At least not in the 42" and under sizes. I believe that pretty much all of them use rectangular pixels. 1024x768 on the panasonic 42" vieras, same for the Pioneer 43" and Hitachi use 1024x1024.
  3. madshi
    madshi
    Jul 18, 2005
    1,145
    48
    Hamburg
    +62
    You'll have to go 50", then you'll get 1366x768 (Panasonic, Fujitsu).
  4. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Only if you are using symmetrical pixels ! Actually, it isn't a big a problem as you imagine - most plasma screens work very well with their internal scalers.
  5. gbech
    gbech
    Sep 3, 2005
    Chesterfield
    Little bit confused by the resolutions here, if a hitachi has a resolution of 1024 x 1024 then how does it play 1080i movies that are 19??x1080 :confused:
  6. DaveP
    DaveP
    Thanks guys, I particularly like this answer. I needed a good excuse to convince the wife we needd a 50"!
    But seriously, if I bought a 1024x768 panel could I connect my PC to it running at say 1600x900 and would it scale accordingly?
    Dave
  7. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    It re-scales them. A plasma has to accept a range of inputs, ranging from (480i/60 - 525 lines NTSC video) up to 1080p, and will re-scale everything that is not native. However, do not assume that you can feed anything in, and it will re-scale - you'll have to refer to spec sheets on individual screens to see the limitations.
  8. johndon
    johndon
    Feb 3, 2002
    1,928
    48
    +89
    The Hitachi effectively overscans when fed a 1080i signal so you lose some of the top and bottom of the image. It scales the image horizontally as do all plasmas that don't have a 1920*1080 resolution.
    John
  9. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Do the newer Hitachi's still do that ? I know my 5300 does.
  10. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    Didn't you mean to say asymmetrical pixels? AFAIK any 4:3 resolution on a 16:9 display that does not have a 16:9 pixel ratio will distort the image.
    E.g. if you fed a 1024x768 into a 16:9 plasma with a native resolution of 1024x768 then the image will be stretched like DaveP suspected since the pixels are not square.
    I also suggest to check the specifications of displays with 1366x768 pixels (or higher) - not all accept the native resolution of the display via the PC inputs, in particular if the refresh rate is quite high.
  11. DaveP
    DaveP
    Indeed, now you mention it, I do recall seeing a 1366x768 panel (50") that said PC resolution was 1024x768. Maybe PS could get round it?
    Oh dear, it looks like I'll have to be going back to the LCD forum!
    Dave
  12. madshi
    madshi
    Jul 18, 2005
    1,145
    48
    Hamburg
    +62
    AFAIK the commercial Panasonic plasmas (e.g. 50phd7) accept native rate at 60Hz.
  13. bishman
    bishman
    Mar 29, 2001
    4,902
    83
    hertford
    +172
    The same way a Panasonic does with 1024x768, they scale the image to fit.
  14. gbech
    gbech
    Sep 3, 2005
    Chesterfield
    So would i be right in thinking that with the current 1080i plasma's around you can't display a 1920x1080 movie file without it losing a lot of the detail due to scaling down to 1024x768 or 1024x1024 in the case of the hitachi's?
  15. Jim_Fear
    Jim_Fear
    May 17, 2005
    1,799
    Caterham
    +59
    Just a question...are we talkign ATi or nVidia? The latest ATi driers actually give you HD resolutions in the Catalyst Control Center, haven't poked about with the nVidia drivers so I cant say about those
  16. DaveP
    DaveP
    I've just changed to nVidia. It also supports the HDTV standards, along with all the others too (EDTV, SDTV etc)
    Dave
