Newbie - Recording question
Discussion in 'Satellite TV, Sky TV & FreeSat' started by TonyDavies76, Jun 30, 2005.
  1. TonyDavies76
    TonyDavies76
    Hi all....
    An idiot question but is it possible to send the digital format recording direct from my SKY+ box (Amstrad) to my computer so that I can write the recording to DVD? (Rather than going down to Analog/SCART and then through the A-to-D capture card)
    Thanks in advance.....
    Tony
  2. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +975
    Nope.
    The first gen PACE box can be SDI modified and that output fed to a SDI card in the PC and that I believe is the only way to do what you want.
    Infact I think some of the Battlestar Galactica captures (off SKY1) were done in this method.
  3. TonyDavies76
    TonyDavies76
    Thanks a lot for the update. :)
    Regards.....
    Tony
