newbie : recording from vhs?
Discussion in 'Cables & Switches' started by barneyman, Jun 6, 2004.
  1. barneyman
    barneyman
    Jan 1, 2004
    50
    UK
    need some help copying vhs to my dvd recorder.
    My panasonic VHS - NVHD625 - is no pretty much redundant, but I would like to copy some old tapes to DVD for playback.
    I have used a scart to connect to the TV - AV1 to AV4.
    I can now see and hear the vhs tape, but now I want to record.
    The DVD manual says I need to connect it direct to the DVD, using audio/visual cables (red, white & yellow). The VHS does not have all three out connectors, just the audio (no visual). :confused:
    Why cant just "ask" the DVD to record what is on the TV ?? I cant seem to see that as a choice but I am hoping someone can help me out...
    Thanks for listening
    :lease:
  2. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    On some TV's you can do just that but not all work the same way unfortunately.
    One answer would be to buy a cable with a scart plug on one end for the VCR and three phono plugs on the other for the DVD Recorder and connect them directly
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,129
    Rainham Essex
    +2,392
    I agree with Ian (see I'm following on behind you this time Ian :D ), but make sure that the scart to phono lead accepts the signal feeding into the scart plug or is switchable. The reason is that the pins on a scart are different for input & output. If you get it wrong then it just wont work.
    Mark.
