Newbie- Quick question
Discussion in 'Cables & Switches' started by T123VOR, Mar 22, 2006.
  1. T123VOR
    T123VOR
    Hi all newbie here,
    I have tried the search facility but it throws up a lot of related but not exact info.:lease:
    Anyway-
    Basically I'm selling my arcam audio (8plus amp and CD) to fund a nice AV set-up (Arcam 88plus DVD, havent decided which receiver yet, Sky+ and my original xbox) what I need to know is:
    Can I use my existing Van den Hul D102 mk III interconnect that I had anywhere on the AV setup or is it now redundant? I want to run component connections where possible.
    Does this sound right?
    Sky+ to AV- R&L audio phono lead plus RGB Scart Lead? Are the Van den Hul interconnects wasted in this config? or sell my VDH and use a cheaper tos-link for the audio? Or just use scart?
    DVD to AV- Hi quality component lead PLUS hi quality digital coax audio? This is where my money is going I think!?
    Any thoughts on this fellas, I'm sure it's been asked a million times before but obviously I want to get it right?
    Thanks in advance
    Trevor
    PS Component leads are definitely Video only- right? No audio?
  2. niceguy235uk
    niceguy235uk
    Jun 14, 2005
    1,880
    83
    +286
    At the end of the day its all down to what av system you are hoping to get.
    All systems work and connect differently, to a point.
    And yes, component is video only.
