JonMace
I have a Sony HS1 Projector and a Toshiba 510e DVD player and the correct leads to connect them have 3 questions
1) The lead I have has component, S Video, compersite (+ L & R Phono) all to a multi- plug into the projector.Which of these should be pluged into the DVD to enable progresive scan?
2)Any ideas what settings should be on the progector and DVD player?
3) I believe I only get progesine scan from the DVD player on region 2 discs is there a hack or chip that will enable region 1/PAL discs to be progresive scan?
