Newbie questions
Discussion in 'Xbox Forums' started by EAZYROG, Dec 30, 2006.
  1. EAZYROG
    EAZYROG
    May 9, 2005
    140
    16
    Hi all,
    I've just got myself a Xbox 360 and have a quick question.
    My TV is a pioneer 436xde plasma, so i will be conecting it via the componet cables supplied with the xbox, this is understand will turn it into a HD DVD player too.
    I have hundreads of dvds from over the years, does this mean my xbox will improve the quality and make them Hi Def quality?
    Any advice, i am a total newbie to the XBOX.
  2. matty555
    matty555
    May 20, 2006
    226
    Nottingham
    +9
    In a word...No Unfortunatley..........
    You will need one of these to play HD DVD through the 360........
  3. matty555
    matty555
    May 20, 2006
    226
    Nottingham
    +9
    its worth checking out this Forum as well....XBOX360.....lots of info on 360's and HD DVD :thumbsup:
  4. Dave2
    Dave2
    Sep 9, 2006
    3,965
    Newcastle Upon Tyne
    +529
    Your dvds will be upscaled via VGA cable and you will get a slight improvement but no way near hd-dvd.
