newbie questions on using a Pio 402 (with Sky, E65 & PW7)
Discussion in 'AV Receivers & Amplifiers' started by Suki G, Feb 18, 2005.
  1. Suki G
    Suki G
    Could anyone help a newbie with my inputs & outputs? :lease:
    I’ve used the existing threads as much as I can but I need a little extra help…
    Can someone suggest a better way of connecting my set-up:
    Sky digibox > Pio 402 (using Video IN/OUT)
    E65 (AV2 decoder exit) > 402 (DVD IN)
    402 (DVR TV IN OUT) > JS converter > Panny PW7
    all via scart.
    Picture and sound from Sky look good to me but there is no picture when I try to play a DVD (just sound). What I am doing wrong?
    I also have a Toslink coaxial cable which isn’t being used at present. How should this be used? :(
    And another dumb question but does this set-up mean that I don’t need the red/yellow/white cables and the component board that came with the Panny?
    Many thanks in advance, S
  2. Suki G
    Suki G
    Please?
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    Suki you need to set the output of the E65 to RGB see the manual set AV1 to RGB and that should get you sound AND pictures
