Newbie question
Discussion in 'AV Receivers & Amplifiers' started by arkaig, Jun 30, 2003.
  1. arkaig
    arkaig
    Hi guys,
    Can somebody explain where the video input sockets come into play on an amp? I take it you can put your DVD out (composite/s-video) through your amp then to your TV? (through the monitor out socket?)
    Why would you utilise this type of connection? I presume the better setup would be....
    DVD > Scart >TV (RGB) & DVD > Optical/Coax > Amp?
    Arkaig/Davie
  2. Jase
    Jase
    Mar 16, 2001
    9,531
    UK
    +931
    Depends how much kit you are using and how many AV sockets your TV has. Receivers can be used as a central hub to switch all the sources. To be honest it's really geared up for the USA market as they don't have Scarts so use S-Video, Composite or Component.
    It comes down to personal preference as to whether you connect direct or go via the amp/receiver. :)
  3. hindutimes
    hindutimes
    Your current connections would be fine in normal set-up.
    Some Amps/Receivers have On-Screen Display (OSD) feature for set-up purposes so you need to connect your DVD S-Video out (as an example) to S-VideoIN (DVD) of the amp then another S-Video cable from the MonitorOut towards your TV.
    I you don't want to connect your DVD to your amp then connect it directly to your TV using S-Video or Scart and use ordinary video single RCA from amp monitorOut to TV RCA input for set-up purposes (if you have OSD feature. remember some amp don't have this)
  4. hindutimes
    hindutimes
    I forgot to tell you.
    My 2011 has a limitation as well. When using component video from DVD -->Receiver --->TV, I need to use RCA connection for OSD set-up
  5. arkaig
    arkaig
    I don't think my Yamaha HTR5550 has OSD. What's HDTV by the way?
