Newbie question
Discussion in 'Plasma TVs Forum' started by plasmawannabe, Apr 16, 2003.
  1. plasmawannabe
    plasmawannabe
    Sorry if you guys get this once a day, but I searched and wasnt really happy with the answers I found and wanted a more current update.
    I really want to purchase a plasma TV, but 3k is as much as I can spend.
    I know about the Gateway model for 2999 and I also noticed that buy.com has a Cornea model for 2999 with rebate.
    Why would I regret buying these cheap models? I will use the plasma for xbox and DVD.
    Thanks very much for the help.
  2. sharon
    sharon
    The difference between those budget models and a Panasonic or Pioneer is really quite significant... I can't comment on the exact models you list but in general you will find lower contrast, little or bad support for progressive scan (important for your xbox), more drop-out (dead pixels) and generally a more washed-out display. You will probably regret it but at the very least ask to see whatever you want to buy alongside a panasonic or pioneer so you can compared.
    Or search around for a cheaper or ex-demo model - I found an exdemo Panasonic 42" for £2350
    Sharon
  3. sonofmoth
    sonofmoth
    Nov 30, 2002
    384
    and also remember that there are other brands apart from Panasonic and Pioneer to choose from :devil:
