Newbie Question
Discussion in 'Portable Disc & Media Players & Recorders' started by monarch3577, Apr 4, 2003.
  1. monarch3577
    monarch3577
    Can anyone give me some advice on how to install an Mp3 jukebox in a Rover 100 ?
    I know how it plugs into the HU, but don't really know how I get a power supply to it (either in the boot or under the drivers seat).
    Any help you can give would be appreciated.
    Failing that, if anyone can recommend someone near Wolverhampton who can do it I'd be grateful.
    Thanks,
    Andy
  2. dnrc
    dnrc
    Dec 23, 2002
    300
    16
    Near Norwich
    You just need to run a power cable from the car's battery to wherever you site the unit. Go through a lug somewhere on your firewall and then under trim/carpet.
    Also, you will need a ground, this is simply a wire attached (securely) to a bare metal part of the car's frame/body.
