Newbie question
Discussion in 'Home Cinema Buying & Building' started by deanogtv, Dec 3, 2004.
  1. deanogtv
    deanogtv
    First off great forum but please bare with me as I'm new to the whole DVD/ Home Cinema world. I've just bought my fist apartment and decided I want a half desent entertainment system. After doing a bit reading up on , I decided to bite the bullet and buy the Panasonic Scht520.
    Question 1 is, can I get the system coded to turn it into a multi-region player, if so where.
    Question 2, Would it be worth up-grading the speaker wires that come with the package to something a bit better.
    Any advance would help.
    Deano
  2. Judders
    Judders
    Oct 31, 2004
    154
    16
    Basingstoke
    Hi Deano,
    Have you already bought? If not, I'd suggest buying one that's already modded, like this http://www.unbeatable.co.uk/CatalogueItem_23393.html
    If you have already purchased, I think you'll need to find someone who can chip it, cos I don't think they're hackable via the remote. Obviously I could be wrong there though. :)
    As for speaker cables, I think it's always worth upgrading them - if you've got the cash to spare. Manufacturers don't tend to ship their kit with top-notch cables cos a) keeps the cost down b) they know darn well you'll replace em anyway!
    Hope that helps.
    Jud.
  3. nathanhill69
    nathanhill69
    Oct 5, 2004
    392
    +19
    As far as speaker cable goes I would actually go against the grain on this (and will probably get shot down by others). When you're talking AV equipment at this price point then the audio performance between using what is supplied and going to the suprisingly expensive business of buying new high quality cable - the difference will be negligible and probably in-audible. This is not to be-little the Panasonic in anyway.
    Of course, it would be a different story if you had spent a thousand or so pounds on AV equipment and then had some cheap cable linking it. I reckon best invest in a high quality SCART linking your TV to the DVD unit.
