Newbie Question
Discussion in 'Projectors, Screens & Video Processors' started by Knightshade, Sep 16, 2004.
  1. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
    Hi All,
    Looking at projectors. Have been told to look for a good projector/Screen with seperate iscan. Anybody any recomendations?
    Haven't got a clue on budget but say High quality well built equipment.
    Thanks in advance.
  2. Barcoing Mad
    Barcoing Mad
    Oct 14, 2004
    1,456
    64
    Norfolk
    +217
    Look for a Barco data or graphics 801s to start yourself off, if budget is limited to about a grand. If you've more to spend, then a BD 808s. Shove it into a search engine and you should find a couple of helpful UK dealers B4 too long.
    The iscan Pro, HD etc are video scalers. A good machine, but always check that it is compatible with your projector- look for sync instability and vertical line wiggles. Again, you're coming in at the grand.
    Alternaitively consider using a PC with decent capture card.
    1.3 gain screen good. 6' to 7' wide, if you're sitting about 14' from screen.
  3. Lux In Umbra
    Lux In Umbra
    LOL, nice and subtle!
  4. Barcoing Mad
    Barcoing Mad
    Oct 14, 2004
    1,456
    64
    Norfolk
    +217
    Afterwards I noticed the banner and realised that subtly wasn't required.
