Newbie question
Discussion in 'Home Cinema Buying & Building' started by logley, Sep 1, 2004.
  1. logley
    logley
    I currently have Sony DVPSS7700 DVD which has 2 scart sockets, Amstrad Sky Box and a Sony 32" WEGA TV which has 3 scart sockets. The Sky box is plugged into the DVD Player which is then plugged into the TV, thus I can view Sky programs and DVD's in RGB.
    Still with me??
    I'm after a All-In-One system, (Sony DC8), but it only has 1 scart socket, how would i connect everything up, so that i can still watch both sky and dvds using RGB, I wont be able to do SKY->DVD->Tv, but can you go DVD->SKY->TV. Or should I be looking at SCART to Composite cables if there is such a thing.
    Hope I've made myself clear.
    Lee.
  2. mevetts
    mevetts
    Oct 31, 2003
    439
    Welcome to the forum! :thumbsup:
    Maybe some sort of scart switcher maybe the way forward. Do a search and you will find a ton of info on this forum.
    Cheers,
    Mark.
  3. logley
    logley
    Cheers mevetts,
    I sort of came to that conclusion after my posting. Currently looking at the B-TEC QUINTRO, anyone got one, what are they like. It says that you cannot swtich it off, thus can get quite hot after prolonged use....any opinions
    Lee.
  4. mevetts
    mevetts
    Oct 31, 2003
    439
    I used this for awhile, worked ok.
    Cheers,
    Mark.
