Newbie question, what cable do I need?
crxpaul
Hi, I'm new to the av thing and I need some advise as to what cable I need to connect my Sub which came with my Tannoy Sfx surround speakers to my amp which is a Sony Str-DA2400ES? I'm pretty sure I don't use normal speaker wire for this although the sub does appear to have these type of connections as an option on the back. From looking at the back of the sub and the sub output on the back of the amp it looks like a different type of cable is required that didn't come with either the sub or amp. Can someone please help me out and tell me what type of cable I need and perhaps a suggestion of a good make to buy and where to get it from. Any help will be hugely appreciated and I know this is a very very silly question but I'd rather double check before I go out and buy the wrong thing. This is the last thing I need before I can fire the new home cinema up so I'm desperate lol!
Thanks in advance! :thumbsup:
biggiegc
Established Member
hello
Normally in these situation you would need a Subwoofer cable!
I would reccomend this site having brought a lot of cable from them myself!
Subwoofer Cables
good luck
:thumbsup:
🎬 The Creator & Reptile, Guardians 3, The Others & Cutthroat Island 4K & Best/Worst Renny Harlin
Back
