Newbie Question - Toshiba internal sub vs external sub
Discussion in 'Subwoofers' started by PeaJay, Jan 13, 2005.
  1. PeaJay
    PeaJay
    Dec 7, 2004
    171
    +15
    As the question says
    My new Toshiba TV is a Dolby Pro-Logic affair. :D
    It has an internal sub. - which does effect the base level quite a bit.
    however, is it worthwhile getting a seperate sub too. The TV has a driver to allow an external sub to be controlled from the tv. So it would all integrate nicely :confused:
    I got this TV to reduce the number of components I had in the lounge - so getting a full AV amp and the works is currently out of the question. (financial controller vetoes it) :rolleyes:
  2. Kazman
    Kazman
    Jan 14, 2004
    5,351
    Luton, Bedfordshire
    +142
    What do you mean by driver? Do you mean a sub out put socket?
    If you have a sub pre out (output socket), then the sound should improve a LOT with an external active subwoofer.
  3. Kazman
    Kazman
    Jan 14, 2004
    5,351
    Luton, Bedfordshire
    +142
  4. PeaJay
    PeaJay
    Dec 7, 2004
    171
    +15
    yep that is exactly what I ment. :blush:
    it has a sub output socket.
    and the Tosh TV lets me switch between the internal sub, or driving an external active sub. :)
    oh, and on the other post - I'd be on a loosing battle on that particular argument. :D :cool:
