newbie question regarding headphone socket.
Discussion in 'LCD & LED LCD TVs Forum' started by MikeKay1976, Jan 4, 2007.
Tags:
  1. MikeKay1976
    MikeKay1976
    Feb 1, 2005
    8,478
    +2,027
    i am in the process of buying a telly (actually i have ordered it) anyway i have just realise i think it has no headphone socket however, it does, as well as it saying built in speakers, have and i quote....
    Line out.... left/right and sub.
    will this be a seperate audio out and not interfere with the built in speakers?? and if not, will i be able to hook this output up to some headphones (am guessing just the l and r will do!!)
    if not i better cancel my order before it arrives!!!!
    cheers
    M.
  2. peahead
    peahead
    Dec 14, 2002
    3,109
    St.helens
    +444
    I would help if you said what make and model of tv it was so we can investigate.:hiya:
  3. MikeKay1976
    MikeKay1976
    Feb 1, 2005
    8,478
    +2,027
    naaaaah that would be too easy ;)
    http://www.evesham.com/products/info.asp?e=F27717E9-08FB-4AD3-BCC7-4F782A11AE6D
    there is a pdf on the site with details.
    i know the SX (which is the same price) DOES have the headphone socket but the TX doesnt seem to.
    however, i prefer the TX as its more space efficient, has dvi and is a newer set so *may* have better components.
    if i can botch some headphones to work using the line out then that'll do i guess
    thanks for reading :thumbsup:
