Hi all
We have had our bathroom refitted recently and we installed 4 Philips Hue GU10 downlights in the ceiling. These are triggered by a motion sensor and also a 2nd gen Hue dimmer switch.
On the outside of the bathroom is a 2 gang light switch. One of the gangs controls the hue lights (and needs to be left permanently on) the other gang controls two small LEDs in a little niche above the bath and also has the extractor fan wired to it. The fan has a timer so stays on for 15 mins or so after that switch is turned off.
My newbie question is: what do I need to install so that the niche lights and fan come on when triggered by the hue motion sensor and then go off after a period of inactivity, while still allowing the extractor to continue operating for 15 mins.
Do I need some kind of relay between the switch and the niche lights and extractor?
Everything is also controlled by Apple Home.
Thanks v much
Thanks v much
