Newbie Question - PS2 connection on PW6
Discussion in 'Plasma TVs Forum' started by Mezman, Oct 14, 2004.
  1. Mezman
    Mezman
    Oct 4, 2004
    13
    Before I start I'd like to thank everybody for the advice I've read on these threads, I've been lurking in the background for about the past month or so!
    Finally took the plunge and ordered a PW6 from av sales on Monday. It arrived about two hours ago and I am well pleased with it so far. As many others have found the customer service is outstanding!
    I wondered if any of you guys can help me with my PS2 Connection though?
    I am running it through a Quintro box and the JS VGA - RGB Scart.
    When I try and switch across to the PS2 nothing appears, I've checked that the output on the PS2 is RGB and the Qunitro is picking up my DVD signal great :thumbsup: .
    I'm sure this must be missing something simple.....Any ideas??
  2. cmorrison
    cmorrison
    same here mate but with my xbox, was advised it may not work with standard scart cable so ive ordered a better cable to solve it.
  3. Mezman
    Mezman
    Oct 4, 2004
    13
    Cheers for that, where do you get the cable from??
