Newbie question - Plasma Panel and what else?
Discussion in 'Plasma TVs' started by empress, Apr 28, 2005.
  1. empress
    empress
    This probably a really basic and stupid question but if I get a plasma panel instead of a plasma tv what other equipment do I need? Im buying everything from new so don't have any old equipment I will be using. I will want to connect up sky+ and a dvd player as well as have 5.1 speaker (at least) setup.
    So is all I need a AV amp that will supplier both the panel and speakers or other stuff like a scaler (I've heard people mention this but not sure what it actually does).
    I have not made any decisions on make ot model of the plasma but once I know what equipment I need I will be able to start research properly.
  2. Mep
    Mep
    Dec 25, 2004
    9,552
    +472
    sky + can be conected to the pc input (also known as vga) on a screen using an rgb to vga converter such as that provided by JS Technology(about £120 plus cables) dvd is best connected via component, dvi or hdmi depending on what you get and whether you go for a standard def or high def screen. You can route video through the amp or just sound.....some amps allow you to connect component, some allow scart, some allow you to input svido or composite and upconvert to component.
    It's a lot simpler than it sounds but you need to decide on sd or hd to start with i think.
  3. nathanf
    nathanf
    Mar 17, 2003
    52
    My plasma is NOT HD ready.
    When will this effect me...?
