Newbie question about Sky Installation
Discussion in 'Sky Digital TV Forum' started by psychopomp1, Jan 18, 2008.
  1. psychopomp1
    psychopomp1
    Nov 19, 2007
    1,309
    +413
    I've never had Sky before so please forgive me if this sounds a dumb question. I'm considering getting Sky HD installed and i believe i will require a BT line in order to get it. I do have a BT line, but my BT socket is in the hallway about 5 metres away from the telly, so can i just use an extension lead to connect to the Sky box? Or does the sky engineer insist that the socket be located close to the box? And also, once Sky has been installed, do i have to leave my telephone line connected to the sky box or can i leave it unplugged? I won't be using Sky's interactive services which require the use of the telephone line.
    Thanks in advance.
  2. Kevosull
    Kevosull
    Sep 1, 2006
    107
    +5
    It does not need to be an actual BT connection box, I'm on Virgin 'phone for example, but the engineer will insist on connecting to the 'phone point, be it an extension lead or the actual box, as part of the installation entails a 'dial-home' (back to Sky) check.
    If you have multi-room, the box must stay connected as part of the contract, but for other subscriptions, I think you can take it out once the installation is done. Sometimes, Sky check to see if your box is still connected, and you might get a request through the post asking you to re-connect it.
    From what I've read, they don't really enforce the connection, as severely as they do if you have the multi-room package.
    hth,
    Kev
  3. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    He will install your box with an extension lead, have one handy if I were you. You will of couse leave it connected permanently to the phone won't you!!!! It's in your contract. If you were to disconnect it, sky might check, and they might send you a letter reminding you to reconnect it. You then connect it, force a callback (ask again here if that is needed) and carry on as you were. In short, it's up to you, there are ways around it.
  4. davemurgatroyd2
    davemurgatroyd2
    Dec 26, 2004
    8,600
    Oxford
    +1,335
    Forced callbacks dial a different number than "Sky requested" callbacks so that trick may not always work (particularly if done frequently or they are suspicious the box is being used outside the UK) when they are asking for connection of phone line.
  5. fernandez
    fernandez
    Jun 5, 2005
    6,039
    +995
    As long as it's not a Multiroom installation, I believe that after the initial callback has been made you can opt out of the permanent phone connection for a once only fee of £25
  6. davemurgatroyd2
    davemurgatroyd2
    Dec 26, 2004
    8,600
    Oxford
    +1,335
    For the £25 no phone option (for single room standard or Sky+) it does not even need to make the initial callback.
  7. GMT
    GMT
    Dec 11, 2006
    178
    +18
    sky now offer the no phone line option for HD.
    however if you want multiroom, obviously you cant go with this and have to have the phoneline.
