Newbie projector help
Discussion in 'Projectors, Screens & Video Processors' started by gunners, May 27, 2002.
  1. gunners
    gunners
    Hi, At work we have NEC LCD projector Mulitisync MT830/1030, which has s-video input. We want to watch the worldcup on it using tv or video as the source which are both sony. Have borrowed my s-video to scart lead which i use for dvd player from home.
    1. Is possible to link the two or three together to get a tv picture on the projector
    2. Is this cable ok or do i need a different one.
    3. How would i go about it seting it up....
    Thanks For any help.
  2. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,357
    Norwich
    +892
    ok
    you only need the video , use it as a tuner.
    firstly is it an s-vhs video ???
    being sony i doubt it.and your lead probably goes from s to scart anyway.
    so you will have to take the feed out as composite, if it has a composite out great, just take that to the video in on the projector and choose VIDEO in the projector settings under source.
    if not you will need to get a scart to phono, and do the above but with scart to phono.
    what are you going to do about sound ??
    can somone bring an amp and a pair of speakers in to work ???
    and run the audio outs from the scart to the amp.
    easiest way ;)
  3. gunners
    gunners
    Thanks for your help dude, iam not worried about the sound as it will be very low :( as there still will be people working.
    Once again Cheers for your help
